Ergebnis 1 bis 15 von 15
  1. Avatar von Gattorantolo
    08.02.2012
    Tessin, Schweiz
    194
    Danke gesagt 1   Danke erhalten 14
    Daumen hoch Online oder Offline?
    Hallo Freunde!...bin neu hier!
    QCN: di WU werde auch offline gültig sein?
    Und was bedeutet "Completed, can`t validate"?
    Habe mal auf den offizielles QCN Forum gefragt und habe folgendes erhalten (auf englisch):
    The original point of this project, was to try and provide rapid, real time notice of an earthquake to a central computer, in the hope that this could be used to warn people to evacuate the area. And this was originally set up to monitor the large number of fault lines along the coast line of California.
    To do this, the computers being used needed to be constantly on line, ready to return a signal.
    As to what you do in your location, being off line at the time of a quake may not matter.
    "Validation" is part of the BOINC software. It's for use when a project needs to check if the data returned is correct. (Maths projects, protein folding, etc).
    To do this, identical work units are sent to 2, 3, or 4 computers. The result returned must be identical from several of these computers (the number being set by the project), before the result is accepted. This is the built in "validation" process.
    For this project, there's nothing to compare between computers. It's just a message that sudden movement has been detected. Checking of this is done by software written for the task, and is outside of BOINC's control or knowledge.
    So that message to which you refer has no meaning for this project. it's just part of the BOINC package, and should be ignored.
    This information has been provided many times over the last few years, in several places on this site.
    STIMMT DAS?
  2. Avatar von Yamazaki
    11.01.2008
    Hamburg
    2.036
    Danke gesagt 36   Danke erhalten 102
    Hallo Gattorantolo,
    ja das ist richtig.
    Die Workunits müssen nicht validiert werden.
    (Würde auch keinen Sinn machen oder ?)
    Yama
    AllProjectStats - PrimeGrid-Stats - UotD - Benutzerseite (Wiki)
    aktuelles Ziel der "SG Aktiv": SETI Wow!-Event
  3. Avatar von Gattorantolo
    08.02.2012
    Tessin, Schweiz
    194
    Und wie sieht es so aus mit Online oder Offline?
  4. Avatar von Yamazaki
    11.01.2008
    Hamburg
    2.036
    Jede Workunit läuft 24h, dann wird sie abgeliefert
    und eine neue geholt. Das sollte gewährleistet sein.
    Checkpointing etwa alle 2 Min.
    Probier es einfach aus.
    Yama
  5. Avatar von Gattorantolo
    08.02.2012
    Tessin, Schweiz
    194
    Frage
    Das bedeutet aber das mann ständig online sein muss...oder nicht?
  6. Avatar von Acid303
    24.07.2009
    1.264
    Danke gesagt 8   Danke erhalten 3
    Nein. Daß bedeutet dass alle 2 Minuten ein Checkpoint fűr deine Wu angelegt wird. Es kann ja sein dass du mal zwischendurch BOINC beenden musst oder deinen Rechner neu startest. Wenn du dann BOINC wieder startest rechnet die Wu vom letzten Checkpoint weiter. Ohne diesen würde die Berechnung wieder bei null beginnen.
    Sent from the Sombrero Galaxy
    „Mich ergeben! Auf Gnad und Ungnad! Mit wem redet Ihr! Bin ich ein Räuber! Sag deinem Hauptmann: Vor Ihro Kaiserliche Majestät hab ich, wie immer, schuldigen Respekt. Er aber, sag’s ihm, er kann mich im Arsche lecken!“
  7. Avatar von Gattorantolo
    08.02.2012
    Tessin, Schweiz
    194
    Ok, danke!
    Aber kann mich jemand sagen ob mann ständig Online sein muss oder nicht? Habe schon überall gesucht aber nichts offizielles gefunden, nicht einmal auf die QCN Home page... Dort wird gesagt dass mann ein Internet Zugang braucht aber nicht wie, wie lange oder wie oft...
    Und was ist mit das...Network Time Protocol (NTP) das funktioniert nur immer online und die WU arbeiten damit...
    Auf die QCN Internet Seite sollte das genau geschrieben sein...aber nichts...
    Geändert von Gattorantolo (09.02.2012 um 12:17 Uhr)
  8. Avatar von schensi
    16.01.2009
    1.804
    Danke gesagt 121   Danke erhalten 22
    Günstig ist es auf jeden Fall , immer online zu sein . Da bei einem Ereignis - sprich Beben , die Daten direkt übermittelt werden . Es werden ja auch in regelmäßigen Abständen "trickles" vom Rechner an die HP geschickt - diese dienen dazu anzuzeigen , ob der Sensor online ist .
    Ich hab jetzt nur keine Ahnung , ob diese einen Einfluß auf die Credits haben wenn sie nicht abgeschickt werden , da ich immer on bin.
    Jens
  9. Avatar von Gattorantolo
    08.02.2012
    Tessin, Schweiz
    194
    Die Credits werden immer gutgeschrieben, auch wenn die WU offline laufen
  10. Avatar von RealSanta
    bei EF
    9.586
    Dann aber gibts credits der credits wegen ... ursprünglicher Sinn ist ja Erdbeben live zu melden und nicht erst 'zig Stunden später..
    unabhängig davon.. schön, dass Verstärkung kommt... denn die ersten 3 sind sehr dicht beisammen... (wenn wer ein QCN-fähiges Gerät hat, der mische doch bei der NCI-App mit...)
    bis denne RS
  11. Avatar von Gattorantolo
    08.02.2012
    Tessin, Schweiz
    194
    Die Daten können aber auch später ausgewertet werden, auch wenn manni nicht online war...
  12. Avatar von RealSanta
    bei EF
    9.586
    das ist korrekt...
    bis denne RS
  13. Avatar von WBT112
    28.10.2009
    meistens unterm Tresen wo ich liegengeblieben bin :D
    654
    Danke gesagt 56   Danke erhalten 6
    Ich missbrauch mal diesen Thread:
    Sonst konnte ich mir immer über die Rechte Maustaste auf die Wu und dann "Computer Triggers" alle zuletzt gemeldeten Trcikels (inklusive Ping Triggers) anschauen. Wenn ich das jetzt mache erhalte Ich nur eine leere Liste. Geht euch das genauso, oder liegt der Fehler auf meiner Seite ?
  14. Avatar von Gattorantolo
    08.02.2012
    Tessin, Schweiz
    194
    Nach ungefähr 2 Wochen werden die "Computer Triggers" automatisch gelöscht und es ist also normal das Sie irgendwann verschwinden...
  15. Avatar von WBT112
    28.10.2009
    654
    Bei mir stehen garkeine drin, nichtmal die Ping Triggers. Gibts die Ping-Trigger nichtmehr und Ich muss den Fehler hier suchen ?
    Edit: Ah ok hab eben mal am Sensor gerüttelt und der Trigger ist dann angezeigt worde. Scheint also im Fall der Fälle noch alles zu klappen
  1. Booster # ist offline
    Von RealSanta im Forum Der SG-Booster
    Antworten: 196
    Letzter Beitrag: 01.01.2015, 10:44
  2. WCG zur Zeit offline???
    Von Blacky im Forum World Community Grid
    Letzter Beitrag: 09.05.2008, 19:52
  3. Online-Durchsuchungen
    Von zipzap im Forum Das Hauptforum
    Letzter Beitrag: 18.04.2008, 20:15
  4. BOINCstats offline ?
    Von gu_wo im Forum BOINC
    Letzter Beitrag: 06.03.2008, 22:28
  5. Offline PC
    Von Genesis Urmel39 im Forum Software - Installation, Probleme usw.
    Letzter Beitrag: 09.02.2008, 15:59
